Do I need a cowl hood with super victor intake?
Old Mar 31, 2008 | 11:06 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Ok, So I recently was forced to purchase a super victor intake manifold part number 2925 because the ports on my head were too large for any other intake. Anyway, it is clearly a much taller intake then the other intakes I was looking at. I placed it on my car with the carb on, but i dont have my nitrous bracket yet and i also dont have my air cleaner on yet. The hood closed. (I have the formula hood)
Does anyone with this intake have suggestions on wether or not I will need a cowl hood or any other raised hood for that matter?
Old Mar 31, 2008 | 11:10 AM
SteelTownMadDog's Avatar
Re: Do I need a cowl hood with super victor intake?
You'll need a cowl hood of some sort. I only have the Performer RPM and the lowest reasonable air breather, and it barely fits under my stock hood.
Old Mar 31, 2008 | 12:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
definitely need a cowl hood without a doubt.
Old Mar 31, 2008 | 12:32 PM
Engine: 388 Carb
Axle/Gears: 4.10
Thanks guys. Time to start shopping and deciding how high to go.
I had the performer RPM sitting on there and it sits about an inch lower then this super victor. Are you using a drop base air filter or regular one?
Old Mar 31, 2008 | 01:40 PM
Won't do much good if the carb's air horn is already jammed flat up against the bottom of the hood....
That's one of the BIGGEST mistakes I see people make. A drop-base air cleaner ONLY works if the lid can still be far enough above the air horn that the incoming air doesn't have to squeeeeze through a tiny little crack and made a sudden sharp 90° to go down into the carb. Kind of defeats the purpose of high-flow heads, big carbs, etc. In other words, the ONLY time a drop-base air cleaner is ACTUALLY any good, is when you don't need it foir hood clearance; and all you're using it for is to add a couple more inches of width to the filter medium.
Firebirds have MUCH lower hoods than Camaros. So if some setup is "tight" on a Camaro, you can be pretty sure, it's not going to work at all on a Bird.
Old Apr 1, 2008 | 08:17 AM
I have a 7/8" drop base with a 3" element.
I did some testing when I was on the dyno a couple years ago and there was only 3-4 RWHP from that drop base to an open carb. Personally, I'm OK loosing 3-4 HP and keeping the stock hood.
Old Apr 1, 2008 | 09:52 AM
Engine: 388 Carb
Axle/Gears: 4.10
I am now on the look out for a good used cowl hood, either 3 or 4". I wanted to keep the body stock looking but I guess that idea went out the window when I decided to build a pretty strong motor.
Hey sofa, adding a carb spacer would just increase the RPM power range correct? Like if the intake is made for 3500-7000 RPM then it would increase it to lets say 4000-7500 rpm? I have read about people using them and had guys at car shows suggest one to me, but i dont want to increase the RPM power range because as of now i am not going to be making much power down low and I want to keep it streetable.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
cougar20th
Aug 27, 2015 08:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
