Lean Bog condition
Old Mar 31, 2008 | 09:25 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
Lean Bog condition
I have a problem where my engine will bog down and often spit back through the carb under light to moderate acceleration. I originally thought it was due to an old TBI system I had. But I replaced it with a carb and still have the same problem! I even put 'richer' accelerator pump springs in the carb. I was wondering if maybe it could be my distributor vacuum advance not working properly? Or maybe a leak in the intake manifold? I installed a air fuel ratio meter and as soon as I put the engine under a slight to medium load it leans right out.
82 Z28
mild 350, Edelbrock performer intake, Edelbrock 600 CFM carb, Mallory unilite distributor, 700R4 w/'stock' converter, stock rear end.
Thanks.
Old Apr 1, 2008 | 12:05 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Lean Bog condition
Whats your timing curve look like?
Old Apr 1, 2008 | 08:18 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Sounds like an intake leak. Get a can of starting fluid and start spraying any place the intake could leak while the engine is running. Also check vac hoses for cracks.
Old Apr 1, 2008 | 09:44 AM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
I installed the cam straight up and set the timing around 8 degrees.
Old Apr 2, 2008 | 03:23 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
I took my distributor out and checked the advance mechanism. It seems to work hard, not sure if that's normal. I put it back together and used manifold vacuum instead of the ported vacuum. The load bog is much better, but I think I missed when putting the distributor back in cause it starts hard like too much advance. But this tells me it's definitely a timing issue.
pjsparts
Oct 29, 2025 06:39 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
middian
Sep 5, 2015 01:42 AM
Jetmeck
Sep 4, 2015 12:29 AM
