Sensor Opinions needed...
Old Apr 3, 2008 | 11:29 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Axle/Gears: 2 series 2.73 drum
I've removed and polished my intake, runners, TB, and a exhaust pipe elbow for my air intake that came out surprisingly well. Before I put all this stuff back on and post pics I need help with 2 sensors....
First is I believe a temperature sensor that screws into the underside of the Plenum somewhat near the f.p. regulator. It looks really crappy. Should I just clean it off or buy a new one and does it matter much?
Second and more importantly I've had idle problems since owning my 87 305 tpi trans am. I think its the IAC. Its really really carboned up in there. Should I just throttle body clean the heck out of it and call hope for the best or reinstall a new one while its off. Though I'm handy with tools and somewhat knowledgeable (sp? lol) the 'how to adjust IAC' in the tech board looks like a real p.i.t.a$$. Can I get some opinions before I put it back together this weekend? As a sidenot I'm worried if I mess withe IAC myself I'll send a spring or IAC part up through the bore in the TB right into my engine. Thanks please help.
Old Apr 4, 2008 | 08:20 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Re: Sensor Opinions needed...
Okay........any help on this one please?
Old Apr 4, 2008 | 10:48 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Clean the TB and change the IAC, just take your time and read, then follow the insturctions. the IAC should be 1 1/8 in from end to the gasket.
The temp sensor, if cheap enough, replace.
92firebirdguy
Sep 1, 2016 07:53 AM
HikoriYami
Sep 21, 2015 07:11 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Night rider327
Sep 16, 2015 02:20 AM
Jlanz55
Sep 8, 2015 11:28 PM
