Cam choice help plz!!
Old Apr 5, 2008 | 04:54 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
ok heres the deal, I want to make my car run at least mid to low 11s on motor up here @ 5800ft altitude(forged and studded 10:1 355ci)....im running 11.8x-11.9x with a 125 shot right now(can get more with some traction and a/f ratio tuning). I am about to do a cam/heads upgrade here shortly, right now I'm running the comp NR288HR and edelbrock rpm alum. 170cc/70cc heads with an air-gap manifold and a 750dp. I'm planning on getting a set of patriot's full CNC ported "super street" heads,195cc, 2.02/1.60, 64cc combustion chambers. Coming down to 64cc from 70cc should bump up the CR to around 10:6:1 and then i'll match that with one of the two custom grind cams that I spec'd out(will probably still shoot a 100 shot to it):
238/248 dur @.050, .540/.550 lift, 110LSA
242/248 dur @.050, .555/.565 lift, 112LSA
The heads are good to .575" lift.....I drive the car regularly on the street so the extra tight lsa's won't work out too well, so i'm looking for the best street/strip compromise here. So, am i on the right track and are my goals possible?
Old Apr 5, 2008 | 06:28 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Cam choice help plz!!
You want to run low 11's on the just the motor? How fast is the motor now?
Old Apr 5, 2008 | 07:07 AM
87nosirocz's Avatar
Car: 87 Iroc-z
Engine: 383 stroker
Axle/Gears: gm 10 bolt 4.10
what did the car dyno at. if your running high 11's your full of it not with out being boosted not up here. im running low 13's with 350hp at the rear wheels to get in the low 11's that thing will not be streetabe at all and have to put down at least 450 to the rear wheels.
Old Apr 5, 2008 | 07:07 PM
read the post and you'll see mention of the 125 shot... and if you're not running at least high 12's with any decently built 383, something is horribly wrong.
Last edited by leeperryracing; Apr 5, 2008 at 07:13 PM. Reason: Automerged Doublepost
Old Apr 5, 2008 | 07:14 PM
on motor, it ran a best of 12.97 but it'll average 13.18-13.2x all day.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
