high idle,then rich,now wont start
Old Apr 5, 2008 | 06:27 PM
RlphKnndy496's Avatar
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
Axle/Gears: 89 2.77 BW 9-bolt disc possi
hello ..i injoy this sight and love to read and lean....but now it's my turn,please help, i'm at my wits end....i have a 91 RS 305 TBI auto 76k...all stock exept no cat, flowmaster in back...i got it a few months ago and has run great ever since....so the only things i have touched are...the idle was a little low for me...so i removed the plug and turned it up a bit...it was fine for awile then it started idleing high...so i tryed to turn down but it dont respond....then it started running really rich all week long...i removed the injectors to look at them and clean...and now it wont start...i did before this jump between a & b and it only flashed service engine ..not code 12...and i get no codes...i'm /was a good mechanic...but this computor controled stuff has me stumped
Old Apr 5, 2008 | 07:23 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: high idle,then rich,now wont start
pull the iac and clean it and iac passage then unhook - battery cable for 5 min. hook back up try it , later jimmy
Old Apr 5, 2008 | 07:28 PM
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
where is the iac..what does it look like?
Old Apr 5, 2008 | 07:42 PM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
4 wire plug on back of throttlebody,unplug then screw it out and clean,jimmy
Old Apr 5, 2008 | 07:51 PM
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
oh..i've cleaned that before...first time some carbon build up week later fine...the little thin gasket did brake the first time...now it's a metal flat washer( which is thicker than stock gasket) is that bad?
Old Apr 5, 2008 | 08:27 PM
Car: 91 camaro RS
Engine: 305 TBI
Transmission: auto
hooked the battery back up...just cranks and cranks no start at all...when i removed the 8 torks on top of TB to look at injectors...could that of messed something up?...i put all o-rings back and such...is my computor fried?...and where is it at anyway?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
