rocker stud torque spec?
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
well im puting together my motor and i am wonder what i should torque the rocker arm studs to? i was thinking 45ft/lbs
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: rocker stud torque spec?
that may work, but my AFR head sheet says studs should be torqued to 60 ft/lbs
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Factory spec for SBC screw in studs into cast iron heads is 50 pounds.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check to see if any of the rocker stud holes go through to the intake ports. Lots of aftermarket heads with large intake runners (190cc+) have the stud holes going right through to the intake ports.
If they do, you will have to use some fuel/oil resistant thread sealer on them. I had to do this with my 200cc World/Dart heads.
New2Chevy
Sep 28, 2015 12:35 AM
