what sensor do I need?
Old Apr 8, 2008 | 01:20 AM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. I have an 86 trans am. Originall, the car was a 305 TPI. It now has a 355 with a miniram on it. The harness is out of an 88 TPI car, but I had my PROM reflashed to a stock 89 350TPI setting, and then tuned to what I have done to the motor from there. My question is, right above where the oil filter is on the block, is an oil pressure sensor. There wasn't anything there with the 86 motor, but apparently the newer cars had a sensor. 88 and 89 models come up with different sensors, so I am not sure if I need the sensor out of an 88, or an 89, or if I don't even need one at all? Please help, the car is almost ready to fire up for the first time in 2 years!!! There is a red plug there on the 88 harness as well if that helps.
Old Apr 8, 2008 | 10:07 AM
Car: 1986 Trans am
Engine: 5.3 LM7
Re: what sensor do I need?
Bump. Anyone? someones gotta know
Old Apr 8, 2008 | 11:11 AM
hitman0187's Avatar
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
i would look at both sensors at the parts counter and see if the plug is different. that may make it easier, other then that i dont think it will make a difference.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
