Main studs
Old Apr 11, 2008 | 12:02 AM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Main studs
I previously bought an engine that was completely rebuilt and decided I wanted to do modifications before I ever put it in, so now I am lookign at more horsepower then I anticipated so I decided to put ARP main studs in. I just wanted some opinions on this because I know some people say I shouldnt do that unless I have the whole thing disassembled and line honed. But I dont want to sink much more money into this engine. From peoples experience I just want to get a consensus on this, if it is wrong or right or what you guys think about it. The motor is a 350 bored .060 over and my main concern is that my cam makes power until 6500 and I will probably keep the rev limiter at 6k for a while but do you think these higher rpms without havign it lined honed could be problematic? Does the little more clamping force from the studs really throw clearances off that much? I have heard mixed reviews. Thanks for all your help.
Old Apr 11, 2008 | 12:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd be worried about the rod bolts, not the main bolts.
Old Apr 12, 2008 | 09:04 AM
gtpro700's Avatar
Re: Main studs
Why do you say that? I have ARP rod bolts. Is it because you thought I had stock rod bolts are something to do with the main studs I did? Thanks for the help.
Old Apr 12, 2008 | 09:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Main studs
The rod bolts have a greater impact on the survivability of the engine than the mains do.
Old Apr 12, 2008 | 10:37 AM
gtpro700's Avatar
Re: Main studs
Agreed. I do have nice ARP rod bolts though so what i was really wondering was the chaning from main bolts to studs after the engine was assembled goign ot be a problem ? Thanks
Old Apr 12, 2008 | 06:44 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Main studs
if you have the studs put them in, otherwise the caps are really the weak points...I can`t remember ever seeing a main bolt stretch beyond yield or break, but caps...that`s another story
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
efiguy
Sep 27, 2015 01:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
