vacuum troubles
Old Apr 11, 2008 | 01:08 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
vacuum troubles
My cam robs vacuum and the engine will die if i sit at idle with my foot on the brake. Will a vacuum canister help?
Old Apr 12, 2008 | 12:36 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: vacuum troubles
No but it will help your brakes.
Raise the idle till it keeps running then retune the idle, fuel and timing, till it will idle slower. Probably it is loading up (too rich) while idling. Retard timing at idle to slow it down.
Or switch to a stick shift.
Real race engines idle at 3000 rpm.
Old Apr 13, 2008 | 06:11 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: vacuum troubles
A good tune and checking over vacuum lines might help. If you have a bigger cam it may be to much for the street.
Pac J
May 17, 2020 10:44 AM
mrbird
Oct 20, 2015 03:43 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
Lmancha96
Sep 25, 2015 08:11 PM
