Compression Question...
Old Apr 12, 2008 | 07:05 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
What would be the highest compression ratio that i could use with ethanol? ethanol i read has an octane rating of around 105? and if i was to use a water/methanol inkection on top of that how much would be do-able? 11-13?
Thanks.
Old Apr 12, 2008 | 07:09 AM
squeeezer's Avatar
Car: 5 cars
Re: Compression Question...
you can do 11 or 11.5 with 92 octane fuel and aluminum heads
i do on my small block
im assumin you have older technology ie, sbc bbc sbf bbf etc
not an lsx engine
Old Apr 12, 2008 | 07:17 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
yeah, its an 88 305...i am looking at some pistons that would get me to 12. something with 54cc chambers, and i am pretty sure i could not do that with 92 octane... but with (technically) 102 octane, would this be possible?
Old Apr 12, 2008 | 07:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why do you want to run compression that high?
Old Apr 12, 2008 | 08:07 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
i am not sure if it was 12 something or 11 something...but i want to make more power and since i am going to be running on ethanol i figured i could take it up higher since ethanol has a octane rating equivalent to 102-105, or so i read...
FormulasOnly
Jul 23, 2018 08:47 AM
Nervous2
Oct 8, 2015 10:53 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
