Right side High-beam light inop
Old Apr 12, 2008 | 12:22 PM
kingair130's Avatar
Car: 1989 IROC-Z/T-tops
Hi,
My 89 IROC has been sitting in the garage for about 7 months now, I start it up every once in a while just to keep its juices flowing, but recently I noticed the right high beam light is out when toggled. I tried jiggling the wires/connectors behind with no avail. Before I start tearing into stuff I wanted to see if anyone had any ideas? Low beams, and fog lights work fine both sides.
Thanks in advance!
Old Apr 12, 2008 | 03:52 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Right side High-beam light inop
so the left side is working fine? probably just burned out, you can get a test light and check the connector to it to see if it is getting power and if it isn't you'll have to trace it back and see why. Check the grounds also.
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
