fuel pump question
Old Apr 14, 2008 | 02:15 PM
96_T/A's Avatar
Car: black '96 trans am
Engine: 5.7 350 LT1
Transmission: 4L60-E 3500 stall
fuel pump question
i ave a 1996 trans am an i have recently replaced the fuel pump. but where i messed up was that i put the wrong one in. or at least thats what the mechanic said. he said i put like a 35 pound in and i need like a 50. and that this is causing the car to not start after it has been running for a while and is warmed up, and whenever i start it normally it takes a few tries.but i really dont want to have to take out the tank and everything again... its such a pain. so i was wondering if i coul put in an inline pump and leave the other intake pump in. and would this solve the problem instead of having to change the intank pump?
Old Apr 14, 2008 | 02:40 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: fuel pump question
Wait a 35 pound pump? Im confused. Have u checked your fuel pressure?
Old Apr 14, 2008 | 02:45 PM
96_T/A's Avatar
Engine: 5.7 350 LT1
i havent checked myself but the mechanic i took it to said thats what i had put in it. but i took the pump out of a camaro z28 of my friends
Old Apr 14, 2008 | 10:11 PM
96_T/A's Avatar
Engine: 5.7 350 LT1
anyone help please???
Old Apr 14, 2008 | 10:30 PM
91chevywt's Avatar
what year z28 is the pump out of? what type of injection did it have? check the pressure with a gauge or have him hook it up and prove it to you...sometimes mechanics are quick to blame the home mechanic for problems.
Old Apr 14, 2008 | 10:43 PM
96_T/A's Avatar
Engine: 5.7 350 LT1
it was a 94 or 95 i got the pump out of and it was tpi. but would putting an inline pump on while the intank pump is still installed work properly? or would it cause any problems because i havent heard of people doing that before
Old Apr 14, 2008 | 11:18 PM
91chevywt's Avatar
I'm pretty sure thats not "the best" idea, but i have heard of people using both together, you just have to wire accordingly. Probably not worth it in the end for a stock car...I know its a pain to switch but it comes with owning one of these. I think a tpi pump should put out 41-46 psi, I know the mpfi pump in my 86 puts out that much. Definetly check it with a gauge.
Old Apr 15, 2008 | 11:04 AM
96_T/A's Avatar
Engine: 5.7 350 LT1
illtry check it toay if i get a chance. an thanks for the help
Old Apr 15, 2008 | 03:03 PM
91chevywt's Avatar
No problem, but remember for the future that you should probably use a new fuel pump on every install, even if you know someone who has a used one. Along with replacing the strainer and the pulse dampener that sits on top of the pump. You know how hard it is to get to that pump, you don't wanna take chances with parts that may be on their way out
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
