Rocker Studs
Old Apr 15, 2008 | 09:07 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
Rocker Studs
Hey guys, I just replaced one of my heads with an RHS OEM head, same as the stock cast and print but it has screw in studs. I was wondering if its possible to take the stock GM studs out of the stock head, and tap the holes so i can throw a pair of 7/16" screw in studs on both heads, sense i have a pair of rollers that are 7/16"
P.s. i have a machinist that will do this, if noted 'safely possible'
John
Old Apr 15, 2008 | 09:37 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Rocker Studs
i had the factory studs pulled from my heads and tapped for screw in studs. been running it daily for about 10 years.
Old Apr 15, 2008 | 09:38 PM
Engine: THREEFIDDY!
Re: Rocker Studs
Awesome. Thanks for the heads up bro
John
Old Apr 15, 2008 | 10:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Rocker Studs
If you have screw in studs now, then 7/16 stud change over should be just simple R&R... the 7/16 studs and 3/8 studs use the same size thread on the base, and the top is bigger. Should just be able to buy new studs and put them in....? At least, thats how I always understood it.
Old Apr 15, 2008 | 10:38 PM
Engine: THREEFIDDY!
Re: Rocker Studs
Let me try to narrow it down, One of my heads cracked.. so i replaced it with an aftermarket OEM head with the same layout and specs as the other stock head. I still have one GM head on the engine, and i want to take the pressed studs out and have them tapped for 7/16" screw in's.
John
Old Apr 16, 2008 | 10:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rocker Studs
Yes, that's completely possible. As mentioned, just the top of the studs is larger.
For your aftermarket heads it's simply a remove and replace deal. The other head will require the factory studs be pulled out, hole tapped to 7/16NC, and the boss milled down for the studs to sit on. Then they will be identical. Your machinist can do this easily. I actually did this by hand with an angle grinder - I don't recommend it.
Old Apr 16, 2008 | 02:26 PM
Engine: THREEFIDDY!
Re: Rocker Studs
Thanks for the info guys, dropped the heads off at the machine shop yesterday, had the valves and what not put in my new head and the other head tapped.. got my studs in and both on my engine, runs great.. ++ i get to brag to my bud about my 7/16" rollers heh'
Thanks!
John
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
