crane powermax cam
Old Apr 19, 2008 | 03:58 PM
85-trans-am's Avatar
crane powermax cam
will this cam with a 480/490 lift work in a lb9 305 with a holly 600dpvs edelbrock performer rpm manifold,holl blue pump,hollyafpr,bone stock heads thanks for the help.
Old Apr 19, 2008 | 06:24 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: crane powermax cam
Needs a lot of gear {4.56 best} {4.10 minimum) and a very high stall converter (3500,4000 stall)
needs higher than stock compression 9.5:1 minimum.
Will need a modified very,very aggressive ignition advance curve.
Needs headers and big exhaust.
The carb will need a power valve change.
Needs a valve spring upgrade. #99848 minimum required
Exhaust guide top/seal to retainer clearance may need attention.
stock exhaust rocker arms/stud clearance @ max lift may need attention.
If you don't have that stuff, then its not your best choice.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
