TBI problem
Old Apr 20, 2008 | 04:36 PM
flracer's Avatar
TBI problem
Hi,im a new member and have a tbi question.My 92 Camaro RS drips fuel from injectors when the key is on.Just bought this car as a project so not much history on it.It runs but only revved up pretty high and its hard to start.Im not much on fuel injection [willing to learn].Any ideas or suggestions appreciated.Thanks
Richard
Old Apr 20, 2008 | 04:39 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: TBI problem
unplug the cts on front of the intake it's a brass sensor.called coolant temp sensor.try that if no work try a a wire in the connector.
Old Apr 20, 2008 | 05:20 PM
flracer's Avatar
Re: TBI problem
Unplugged sensor and put in a jumper wire still no go.The left [drivers]side of throttle body is pouring out gas even a minute or so after turning off key.It tries to start but acts like the timing is to low [maybe just flooded with gas].
Stevo thanks for quick reply and your help.
Richard
Old Apr 20, 2008 | 06:02 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: TBI problem
it sounds like a bad o-ring on the injector. you have to remove the injector pod, its 7 torx screws i believe and then pop out the injector that is leaking and inspect the rubber o ring, probably not seated correctly or is no good.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
