No TPS Reading?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
No TPS Reading?
I tried to check the reading on my throttle position sensor with a multimeter and no reading comes up. Does this mean that the sensor is bad?
Transmission: 4L80E/4L80E
May mean it doesn't have any voltage going to it, or you aren't probing the proper wires.
Car: 92 Camaro RS, 04 Dodge RAM
Engine: 305 TPI / Hemi 5.7L
Transmission: 5 speed / 4x4 auto
Re: No TPS Reading?
five7kid - I have a code 22...low TPS voltage. I check it and got a reading so far down on the range that it puzzled me. My reading was .03 with my meter set at the 12vDC setting. I know it's supposed to be in the .54 volt range. I can't get the sensor, even at max setting to get any higher then .07volts. The sensor seems to have a full range up to 1.9 v when advancing the throttle. I previously got the correct readings at last tune up. Think its a bad TPS? Any thoughts?
Car: 85 Iroc-Z
Re: No TPS Reading?
I am probing the right wires (neg on top pos in middle). Ill check to see if I have voltage from the connector.
Car: 85 Iroc-Z
Re: No TPS Reading?
I checked for power from the connector and the only wire that had power to it was terminal c (gray wire). The light was extremely dim though. Could this be a problem?
Re: No TPS Reading?
85iroc-z - between the A and C terminals you should get a reading of 5 volts. Like you I too am getting a low reading of only 3 volts here and I'm wondering if I have a bad TPS. Hoping five7kid checks in and lends his opinion to us both.
Car: 85 Iroc-Z
Re: No TPS Reading?
Any clue what might be causing the dim light? What should I look into?
Get a digital volt meter. A light isn't going to tell you anything.
Car: 85 Iroc-Z
Re: No TPS Reading?
I used a volt meter but i cant get a reading from it.
Car: 85 Iroc-Z
Re: No TPS Reading?
I guess I just didnt make good enough contact. I tried it again and it read fine.
Re: No TPS Reading?
five7kid-I just replaced the TPS and I still get a low reading...around .03 volts. Any ideas where to look next? I hate electrical gremlins.
Linson
Sep 21, 2015 01:08 PM
MikkoV
Sep 9, 2015 04:25 PM
