Quick question, easy answer? Car wont run
Old Apr 22, 2008 | 01:27 PM
Notbychance's Avatar
The car has spark and fuel but a few components from the engine are missing. The car will fire but runs awfull. The engine and car have 100k. I was thinking that by putting on the airtube and 02 sensor combined with putting whatever those hoses should go to will fix it ( picture attached). It would be nice to know where Im at before digging in. I would like to know your thoughts. thanks very much for looking
Red 87 350 GTA T-top digital dash
Attached Thumbnails Quick question, easy answer? Car wont run-dcp_0658.jpg   Quick question, easy answer? Car wont run-dcp_0638.jpg
Old Apr 22, 2008 | 01:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It would also be helpful to know year, engine (I'm guessing '86 or '87), induction (can see now it's TPI), and any modifications.
If the O2 sensor isn't there, it will never run right.
No alternator?
Old Apr 22, 2008 | 01:47 PM
Re: Quick question, easy answer? Car wont run
Its a 1987 350 tpi bone stock. I bought it at an estate auction. I heard from a friend it ran fine until the guy took it apart to start on the manifold gasket leak. I believe a box got lost of the parts in the process. The alternator is off at the moment, I had to put a new manifold on. The car runs so bad it dies, it doesnt come close to running right. Is there some smog stuff missing, is that what those hoses are for? Does a vacum leak occur? Id like to figure out if i get the intake on therefore fixing the o2 sensor, replace the stuff missing from the end of those hoses and of course put the alternator back on will this most likely run right?
Old Apr 22, 2008 | 02:13 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
looks like the air cleaner assembly with the MAF sensor is also missing
Old Apr 23, 2008 | 04:46 PM
bump
Old Apr 23, 2008 | 04:57 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Your best bet may be to find someone with a TPI car that is local so you can compare. That or get a shop manual and go through everything.
Old Apr 24, 2008 | 09:32 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Yes, there is some smog stuff missing. The pump and diverter valve are not there, but wouldn't cause the car to run bad, and shouldn't be causing a vacuum leak. It wouldn't hurt to check that none of the vacuum lines are broken or disconnected.
Try hooking up the air intake and MAF sensor assy, not having that in place will definitely make the car run bad.
Dave
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Aug 24, 2022 05:11 PM
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
