will these heads fit?
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
can i put LS1 heads on a LB9 car? will they work right? will i see any power gain?
Transmission: 4L80E/4L80E
The answer to the first question is "Yes, you can put them on the car (they would look pretty funny on the roof), but you can't put them on the engine."
That being the case, the other two questions are moot.
Re: will these heads fit?
yea, ill put em on the roof then. anyoen need some ls1 heads? lol.
The LS1 was almost a completely clean sheet of paper. The number of parts that interchange is very, very small.
Great engine, though.
Which heads are they, exactly?
they are off of a 1999 LS1 camaro.
You should be able to get something out of them. Apparently the '98 heads were one-year-wonders, and nobody wants them.
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
