SDPC Vortec head question
Old Apr 25, 2008 | 06:54 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I am about to buy a set of SDPC modified vortec heads. Now for my set up I only really need the .525 max lift vortecs but for an extra $5 I can get a set of modified vortecs that are good up to .600 lift. What is the difference between to two sets beside the obvious that one can handle more lift than the other. From searching around I keep hearing people talk about there vortecs can handle .575 lift with a roller cam. Which set of heads are they referring to? Either the roller cam allows more lift with the .525 or allows less lift with the .600?? I was just thinking that in case I decided to chance up my combination the .600 max lift heads would probably be the better bet, but I am not really sure. I just don't want to buy the wrong set of heads if I decided to go with a bigger cam in the future.
Below are the two sets of heads in question.
http://www.sdparts.com/product/SD806...25Springs.aspx
http://www.sdparts.com/product/SD806...00Springs.aspx
Kevin
Old Apr 26, 2008 | 06:07 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: SDPC Vortec head question
Be honest with yourself about what the engine will be used for.
If it's going to be used mostly at the dragstrip get the .600 heads.
If it's going to be driven on the street the .525 heads are a better choice.
The shorter (.600 lift) valve guides will wear faster than the longer ones.
If you look at the cams with up to .525 lift with 1.5 rockers, they are more than adequate to get you below 12 miles per gallon on the road.
If you get the urge to use 1.6 rockers and go above .525 you can use offset locks and shim the springs.
When you come to your senses and put a streetable cam back in it, you will still have the longer-lasting guides.
Old Apr 27, 2008 | 03:02 PM
Engine: L98 350 TPI
So the valve guide hight is the only difference. I have been searching every where to find what the differences are between the two. What do you think the life expectancy difference of the valve guides is between the two?
Old Apr 27, 2008 | 04:56 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I could be completely wrong here, but I would expect that there should be a difference in the valve spring specifications between .525 lift and .600. I see that they both mention "Z28 springs", whatever they are.
Also, all the head flow data that I have seen on Vortecs show them choking up much after .500 lift. If you are thinking about a cam larger than that, I would keep it in mind.
Old Apr 27, 2008 | 05:02 PM
Engine: L98 350 TPI
I am going with http://store.summitracing.com/partde...8&autoview=sku as my cam. Its not to o crazy just enough for me. I just want be able to go with a larger cam in future if I wanted to, that is after some decent head work.
Kevin
Old Apr 27, 2008 | 05:16 PM
Engine: 350 4BBL
Originally Posted by jtrescot
I could be completely wrong here, but I would expect that there should be a difference in the valve spring specifications between .525 lift and .600. I see that they both mention "Z28 springs", whatever they are...
To quote the SDPC, they cut the "stock" (.450 lift) guides down for the for .525 lift heads and put better springs on.
For the .600 they cut the guide down even further and change springs again.
Originally Posted by SDPC
When using more than 0.450" lift with your Vortec heads, we recommend using our high performance valve spring upgrade Vortec heads. After machining the valve guides for clearance, we install our high performance Z28 valve springs with lightweight LT4 retainers. This produces a high revving cylinder head that can handle up to 0.525" lift on hydraulic camshafts.
If it didn't make a big difference in longevity they would put the .600 lift guides in all of their heads.
Old Apr 27, 2008 | 08:00 PM
Engine: L98 350 TPI
Thanks alot guys for clearing this all up for me.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
