Blue Smoke, New Valve Seals
Old Apr 27, 2008 | 09:19 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car is smoking on start up and I cant figure out why. I just put valve seals in it and the car has only been driven about 5 miles since then. The engine was freshly built also. What could be causing this?
Old Apr 27, 2008 | 09:26 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Blue Smoke, New Valave Seals
faulty head gasket? intake gasket? might have not sealed up right when u put the heads back on,,,, gaskets are cheap..sbc are easy take it goo and do it again, make sure you use the proper torque sequences when taking the heads off and putting them back on...
Old Apr 27, 2008 | 09:43 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Blue Smoke, New Valve Seals
Valve guides could be worn or the valves themselves could be worn.
Old Apr 27, 2008 | 10:20 PM
jem1975w's Avatar
orm and freshly built motor then why new guieds u might need to drive car for 1,000 miles then sees what happens do u have duels or fact
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
