-32 oil temp??
Old Apr 25, 2008 | 10:29 PM
Cassidyz28's Avatar
Car: 92 Camaro Z28 Convertible
Engine: 5.0 Tpi
-32 oil temp??
Hey everyone,
This is my first post and i'm looking for some help. I recently used an obd scanner to view my live vehicle data ie:temps,voltage etc.. My car, by the way is a 92 z28 5.0 tpi. Everything seemed up to par but the scanner thought that my engine oil was like negative 32 degrees which i know isnt right. I'm guessing that I have a bad sensor somewhere but im not sure which one. I thought cts but I think that its only for coolant. Then I though oil sender but isnt that just for pressure? Anyways, I'de like to fix this. Any input from you guys would help.
Thanks in Advance,
Patrick
Old Apr 25, 2008 | 10:36 PM
midwest's Avatar
Re: -32 oil temp??
-32 is the what you get when, its -32 degrees outside, or the sensor, wiring or that part of the computer is "open" A quick test and this goes for coolant temp as well is to jump the connector with a paper clip, If the scan tool , goes from -32 to +250 or higher, then the wiring and computer is fine, and the sensor is messed up.
Old Apr 26, 2008 | 08:49 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: -32 oil temp??
Originally Posted by Cassidyz28
... My car, by the way is a 92 z28 5.0 tpi. Everything seemed up to par but the scanner thought that my engine oil was like negative 32 degrees which i know isnt right...
That engine doesn't have an oil temp sender. The scan tool will always report this value.
Old Apr 26, 2008 | 12:14 PM
Cassidyz28's Avatar
Engine: 5.0 Tpi
Re: -32 oil temp??
Thanks dude...
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
