power numbers??
Old Apr 26, 2008 | 05:18 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
power numbers??
hi, on a 305 tpi with comp cams 262(a step above the lt1 cam) and trick flow super 23's 175 intake 67 exhuast 56cc and slp runners..what kinda numbers would i expect at the crank ?
Old Apr 26, 2008 | 06:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: power numbers??
none your engine must be missing pistons as you havent mentioned a CR
Old Apr 26, 2008 | 07:52 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Re: power numbers??
its still got the stock pistons...the stock CR was 9.3.1..but i dont know what it would be after all the work i was lookin for about 270/280 crank hp/tq...camm specs are 206/210 450/480 112 lsa those heads with slp runners
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
ezobens
Aug 19, 2015 10:29 PM
