tbi heads question
Old Apr 28, 2008 | 10:46 PM
white91's Avatar
Car: 91 CamaroRS convertible
Engine: 305 TBI
Axle/Gears: stock
tbi heads question
I have a 91 305tbi. I know they suck but how bad are these heads really? Is anything that can be done to them that would be worth while or is it just a waste of time?
Old Apr 28, 2008 | 11:48 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: tbi heads question
They will make flow that keeps the power band at a table top level to about 5000, then thats it, no real power but it is constant.
Old Apr 29, 2008 | 01:02 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
187's will support around 300 hp ported. They're really not as bad as people in the past have put them.
Old Apr 29, 2008 | 12:13 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, not too many folks wanna settle for 300, but some are happy as can be.
Old Apr 29, 2008 | 02:14 PM
white91's Avatar
Engine: 305 TBI
Axle/Gears: stock
Ok. I have never ported a set of heads before. How difficult is it and is there anywhere I can find out how to do it with out ruining them?
Old Apr 29, 2008 | 08:54 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Honestly, those heads are harder to port than most due to the swirl design, i say you should do some study work on porting for a bit, then geind on a set of junk heads and go from there with the opinion of a experienced porter to give you tips, it takes several hours to port a set of V8 heads alhough aluminum will go quicker it is easier to take too much, but aluminum can atleast be fixed. So, do plenty of research first off, learn what all the different things to do are(short side, long side, blowl blending) and then practice you self till you become decent, you will also need to find a good set of tools.
Old Apr 29, 2008 | 09:04 PM
white91's Avatar
Engine: 305 TBI
Axle/Gears: stock
Thanks for the advise. I was just doing some read on porting. Dang there is a whole lot more involved than I thought. Thanks again.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
