Engine shudder/shaking around idle speeds. Ignition?
Old Apr 29, 2008 | 09:08 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Sorry this got kinda long. Alright, I have a carbed 350 in my car, basically EVERYTHING is new on the car. I'll cut to the chase. After changing to shorty plugs and cut to length wires, every once in a while my engine will shudder around idle speeds. I have not found any relevance as to when it does it.
Stuff I have noticed that makes no difference: engine temp, idle speed, variations in base timing, idle mixture, in gear or nuetral.
It is not a constant problem, it will only happen every once in a while. It will do it for maybe a few seconds, usually noticed while backing down the driveway.
Now I would look first at the fact that this problem seemed to start occurring after I swapped plugs and wires.
MY NEW WIRES ARE ROUTED IN A TIGHT BUNDLE from the back of the heads to the dist cap. Could this be it? It isn't missing or having any other symptoms I can notice. I've checked for arcing at night, no obvious damage to wires, caps are tight, etc.
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
