Where are the Jack points?
Old Apr 29, 2008 | 09:39 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Hope this isn't a stupid question, but where should I put the jack under my 91 rs convertible?
My chiltons manual shows jack points but the under side of my car looks nothing like the diagram in the manual. There are rails just inside the GFX, but they appear to be square tube sheet metal, not actual frame rails.
I don't actuall see two straight rails like in the picture in the manual. The only things that look anything like those rails is way closer to the center of the center of the car and it doesn't look like the car would be stable on jack stands there. I have a feeling I'm missing the obvious here. Anybody have a photo? thanks
Old Apr 29, 2008 | 11:59 PM
Nsomnia's Avatar
Re: Where are the Jack points?
These are subframed cars, they dont have frame rails.
There are 'rails' that look like they are built into the body that have holes in them for jack stands (i presume) in the front and back very near the edge of the car by where the gfx would be that I use and they are strong enough. I like to use the rear end and subframe underneath the engine. This is on an 87 btw.
You could use the engine balancer if you were desprete enough (please dont), the moral is, if it looks alright it probably will be, just dont get under it unless its fully supported.
Old Apr 30, 2008 | 07:43 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The proper places to jack a thirdgen and support with jack stands is covered
https://www.thirdgen.org/forums/tech...t=torque+boxes
here
gixxer92
May 18, 2017 11:20 AM
z28joe2
Sep 28, 2015 05:54 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
