does anyone have a pic of a non a/c power steering pump bracket?
Old May 4, 2008 | 11:54 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
I get rid of the A/C and got a supposed non a/c bracket. It is only one bracket is there supposed to be more then one piece? The a/c one was 3. Not sure how to make the one bracket i have work.
Old May 5, 2008 | 12:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: does anyone have a pic of a non a/c power steering pump bracket?
You using v-belts or serp?
For v-belts
https://webdisk.ucalgary.ca/~jmknopp...de%20motor.jpg
Old May 5, 2008 | 03:09 PM
Damon's Avatar
That picture shows an A/C equipped setup. The lower brace is used on A/C cars as well and bolts to a stud on the back of the PS pump. The upper one is definitely for an A/C equipped car becuase that's what came stock on my A/C equipped Malibu in 78! There is a down-piece that bolts to the exhaust manifold and interlocks with that upper brace that is missing from the picture as well.
Old May 5, 2008 | 08:10 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
For v-belts
The lower piece is non a/c the upper piece is with a/c but i looks like it would work i have both of those pieces. The lower one is the one i couldn't figure out where it bolted to.
Old May 5, 2008 | 11:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
My car definitely never had A/C but it had those brackets. :shrug: I'm now not using the upper one, since I realized it is only needed for the spacer on that stud. I just use some washers I think now.
Clear as mud then F355bird?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
