Head studs
Old May 6, 2008 | 06:25 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Head studs
just got in a set of arp head studs for the motor im building. What kind of sealent do yall recomend i use in ur oppinion?
Old May 6, 2008 | 06:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Head studs
If the head bolt holes go into a coolant jacket like most SBC blocks do, use a normal pipe dope. I like PST myself. If the holes are blind, just a little bit of oil is needed. Head studs are not torqued in. You screw them in by hand and just snug them up. The clamping force is from the nut, not from the stud.
Old May 6, 2008 | 08:57 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: Head studs
but wouldent when you torqe the bolt the stud would screw farther into the block? or if you ever had to take the bolt off wouldent it take the stud out with it?
Old May 6, 2008 | 08:59 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Head studs
well it could if the nut was stuck on the threads but as soon as the pressure is released from the head there is no longer any preassure on the stud so only the nut should come off when done properly
Old May 6, 2008 | 09:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Head studs
http://www.arpfasteners.com/Catalog/...atalog036.html
Read the section in the highlighted box
Old May 13, 2008 | 06:29 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: Head studs
is PST an abreviation or is that the actual name of the product? where can you get it at just local auto part store?
Old May 13, 2008 | 08:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: Head studs
Loctite 592. PST, Pipe Sealant with Teflon.
http://www.hrpworld.com/index.cfm?fo...action=product
http://www.amazon.com/Loctite-Thread...727587&sr=1-21
italiano67
Dec 11, 2016 09:21 AM
Magman
Sep 12, 2015 10:43 PM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Aug 25, 2015 12:54 AM
