Name that Part
Old May 7, 2008 | 07:06 AM
slicef96's Avatar
Car: 1987 Trans Am
Engine: LB9 5.0 TPI
Transmission: Manual
Name that Part
I replaced the coil yesterday and I found something I can not identify. There is a bracket that screws in to the same screws as the coil. It holds what appears to be some sort of Vacuum related item which sits to the right (passengers side) of the coil. One side has two tubes going in using a rubber jack that lines both up. The other side has a space for a hose with a little metal bracket that should hold the hose in place, but there is no hose. Can anyone tell me what this is and where the missing hose should run?
Old May 7, 2008 | 03:09 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Name that Part
It's the EGR solenoid valve.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
