Harmonic Balancer woes
Old May 7, 2008 | 11:28 AM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
During a recent thirdgen cruise, I noticed a metal rattling sound when I'd shut off the engine. Dyno Don from here looked at it and said the rubber ring had come off the damper, but I'm a bit confused. Check out the pic:
From all my reading up, Part A is the damper (harmonic balancer), and Part B is just a pulley I guess. But when I looked, it was Part B that was wobbley, and Part A didn't seem wobbley, or maybe just very slightly. So my questions:
-If Part A is the balancer and needs to be changed, Do I also have to change Part B because it was wobbley?
-If I need to change B, how do I remove it?
-Do I need to know the right bolt size and threading before going out to buy a Harmonic Balancer puller/installer? Or are the bolts universal?
Thanks.
Old May 7, 2008 | 11:45 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: Harmonic Balancer woes
Part A is just the balancer pulley, the actual balancer is right behind there. To get to the balancer, you need to remove all the belts, the three bolts holding the pulley on, and then the crank bolt. Balancer puller should be standard size, as long as its for a SBC.
Part B is the power steering pump pulley. If the pulley is wobling, then it sounds like the pump is about to go t/u on ya.
Dave
Old May 8, 2008 | 02:13 PM
Thanks. I hope it's not the power steering pump. I got a new one installed only last year. Is it possible that a wobbley pulley could damage a perfectly good p/s pump?
Old May 8, 2008 | 04:53 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
pulleys don't just get wobbly unless they have a bearing,, power steering is a press fit onto the shaft.
i hate to say it but if you had one installed,, thats probably the problem. (SHOULD have installed it yourself)
anyways.. if you want to do a quick test on the balancer/damper go under the car and try to wiggle it, its the big round black thing right off the crankshaft.
you sound new to cars with the part a part b talk, but the people on this site will definetly assist you
does you steering whine when you turn?
Old May 8, 2008 | 05:42 PM
Yeah until recently I wasn't too involved with my T/A's mechanical aspects mostly cuz it had to be driveable on a weekly basis, so it couldn't just sit on stands for weeks on end while I figured out its problems.
I'll check the balancer tonight. So far it turns fine-- no whines.
Thanks.
Old May 8, 2008 | 05:48 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
An easy way to check would be to take all the belts off, start it and listen for the noise. The balancer will be turning but the PS will not.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
