Idle Air Speed Screw
Old May 9, 2008 | 01:24 PM
Spitzfiya's Avatar
This is on a 87 Trans Am GTA / 350TPI L98
So I adjusted the Idle Air Speed Screw because I felt the idle was to low and almost on the verge of a stall.
I saw this sticker under the hood telling me NOT to mess around with this screw after I messed around with the screw (Figures)
So I guess what i'm wondering is did i damage anything by messing around with this screw? Do I have to reset anything now? because it seems the ECM controls the idle? correct?
I did disconnected and reconnect the battery after every adjustment.
I did notice drivability issues after setting the screw tho...the idle just seemed all over the place not to mention it would stall out and bog down.
Heres what i adjusted it to:
Heres what i put it back to:
I figured this was the place it was at stock originally because of the wear on the inside of the Screw hole, and the throttle linkage wear.
seems odd its backed off all the way.
I "kinda" remember it being like that originally...but im just not sure
Does this look like the correct position for the screw?
Old May 9, 2008 | 05:59 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Idle Air Speed Screw
that screw should just hold the blades off the bores to prevent them from getting stuck closed
Old May 9, 2008 | 07:20 PM
Spitzfiya's Avatar
Ah ok i see so just a little bit of pressure on the screw?
Is that how everyone else has theirs set?
Old May 10, 2008 | 08:45 AM
Vader's Avatar
There is a procedure for adjusting that screw. Perform a SEARCH of the board archives for "throttle minimum air" adjustment and you should find plenty of help.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 15, 2015 01:17 PM
