stumble stumble
Old May 10, 2008 | 05:43 PM
THE HOFFMEISTER's Avatar
Car: 89 Trans Am GTA
stumble stumble
The last few times i have taken the car out, iv'e noticed that
when its cold, there is an off idle stumble.
And sounds really lumpy (like its got a huge cam, which off course it aint)
Its runs fine once its warmed up some, but cold, it just stumbles and dont
respond striaght away.
Thing is, i recently installed an air foil in the throttle body, now, it was fine before i added this, do you think it could be this affecting it some how when the engine is cold? or is it just coincidence?
what ya think, any advise is much appreciated.
Old May 11, 2008 | 11:19 AM
Vader's Avatar
Re: stumble stumble
Remove the air foil and see if it helps.
Old May 11, 2008 | 01:27 PM
Re: stumble stumble
Yea, i was going to, but aint had the chance yet.
Just wondered if anyone else found that they had the
same effect on their car.
Should get time tomorrow.
Old May 13, 2008 | 01:04 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: stumble stumble
I don't think they're related as I am having the exact same problem, I've already figured that it's not wire, plug, cap, or rotor related. adjusting the TPS helped very little. I'm going to check my fuel pressure and IAC next. my car also likes to cut out when I touch the throttle when it's cold.
Old May 16, 2008 | 03:39 PM
Re: stumble stumble
didnt think it would be the air foil and it werent, was the same when
i took it out.
You had any luck checking fuel pressure and IAC?
I'm not too concerned, coz it clears quite quickly, but it is annoying.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
