Mysterious White Smoke Coming out Exhaust
Old May 15, 2008 | 09:27 PM
TransAmKid87's Avatar
Car: '87 Trans Am
Engine: 5.7 Liter V8
Transmission: 4 Speed Automatic
I have a 1987 Pontiac Trans Am, on my way home today i noticed that my car is running really choppy, there is a thick white smoke coming from the exhaust, the smoke smells like gas... so much its nauseating. I've been told that white smoke is due to coolant/antifreeze getting into the cylinder. But the coolant level is going down as if there was a leak. any one have any ideas??
Old May 15, 2008 | 09:35 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Mysterious White Smoke Coming out Exhaust
Makes sense. if it is getting into the cylinder and burning, the coolant level would go down.
Old May 15, 2008 | 09:42 PM
Car: '87 Trans Am
Sorry typo, the coolant level is NOT going down. Also i have read about the possibility of diesel fuel contamination. it was filled up on monday but started running terrible today (thursday). and there was no gradual drop in performance either. it ran fine on the way to my destination, but ran like crap on the way back.
Old May 15, 2008 | 10:02 PM
campin1983's Avatar
Well do you have a reason to believe it has diesel in it? If so, I'd say drain the tank and refill with good gas. If not, that's a lot of hassle to worry about just a hunch.
Also, have you checked to see if you've got oil in the coolant? Could be you've blown a head valve gasket or something like that.
Old May 15, 2008 | 10:05 PM
ManicMechanic88's Avatar
Car: 1989 Chevy Camaro IROC Z Convertabl
Engine: 5.0L 305 w/TPI
Transmission: Stock 5 speed
Axle/Gears: Stock Posi Trac
Sounds like a blown head gasket.
Old May 16, 2008 | 03:54 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I would vote for head gasket too.
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
TheExaminer
Aug 26, 2015 04:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
