168-tooth or 153-tooth flywheel?
Car: 1986 Z28
Axle/Gears: Stock :(
I have tried searching this topic with no luck. I have a 74-76 350 with a 2 peice rear main seal and a T-5 transmission with stock bell housing. Which flywheel should i purchase? I can get a 168 or 153 tooth for my engine. I haven't purchased a starter yet, so that doesn't matter. Any help would be appreciated
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 168-tooth or 153-tooth flywheel?
The 153 unless you plan to run an 11" clutch. What's the part # on the bell housing?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get the 153 tooth - 168 tooth will not fit inside a T5 bellhousing.
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Like the others said, you want the 153 tooth flywheel. Btw, I have a billet steel 2pc 153 tooth flywheel that I no longer need. I bought it new and it still is in great shape. $75 shipped.
Car: 1986 Z28
Thanks for the info. That is exactly what I needed. The bellhousing the stock one. don't know the part# and I pland on using a stock size clutch.
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
