Do I need a New Fuel Pump for my V6 to V8 conversion?
Old May 22, 2008 | 06:20 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
Transmission: 700R4 by Monster transmition
Axle/Gears: Borg warner 3.08 posi
Ok so I dropped a V8 350 with a TBI injection (88 suburban injectors) into my 89 RS V6 2.8L car. I used the wiring harness out of a 91 5.0 TBI RS. It idels and starts fine but loses power as the RPMs climb.
Do I need a new fuel pump? If so witch one?
Old May 22, 2008 | 06:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In theory, no, but the only way to know if fuel delivery is your problem would be to get a pressure gage on it and see what happens when it acts up.
Old May 22, 2008 | 07:04 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: Do I need a New Fuel Pump for my V6 to V8 conversion?
what did you do to make the fuel pump come on for both injectors? have you adjusted your timing? i have the same conversion (kinda)... 89 2.8 to 5.7 92'. only 1 injector is firing, but i have to manually give it power, let me know what you did please.
Old May 22, 2008 | 07:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
At what RPM does the power start to drop? Stock TBI engines were never known for their high RPM power....
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
el_muerte
Sep 16, 2015 12:01 AM
m00n420
Sep 11, 2015 02:39 PM
