fuel pump?
Old May 25, 2008 | 02:50 PM
310IROCZ's Avatar
fuel pump?
Hello all, I have a fuel issue.I think the fuel pump may be on its way out. it makes a humming noise when ever the car is running car runs fine for about 15min then seems to start starving for fuel over 2000 rpm. here is the kicker, when it acts up if you shut off the car and restart it, its fine for another 15 min. its a tpi car. any ideas?
Old May 25, 2008 | 03:55 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: fuel pump?
i would replace the relay under the hood on the firewall and see if that helps. should cost about 10.00 try that first then decide if you will have to have the fun project of dropping the gas tank.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
