Idle Shoots Up Immediately After Starting...
Old May 23, 2008 | 04:09 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
I'm not sure if this is normal, because I've never noticed it before. When I start my car up the idle steadily goes up to 1500 or 2000 and then steadily drops back down to "normal" idle which at cold is alittle more than 1000rpm I think. I've just started noticing this after installing K&N air filters and changing the oil. Any ideas? Drivability hasn't been affected and it runs fine and all other gauges are normal but if there is a problem I wanna identify it before anything comes of it...
BTW, the engine is a 305 TPI w/ 32k miles.
Old May 23, 2008 | 06:47 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Idle Shoots Up Immediately After Starting...
im having the same issue anyone have any ideas
Old May 24, 2008 | 06:10 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
I'm pretty sure that this is normal. I'm yet to see a third gen that doesn't do that.
Old May 24, 2008 | 06:51 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Could try cleaning the IAC.
Old May 25, 2008 | 07:16 AM
Car: '86 Iroc Z
I replaced my IAC, TPS, and recently rebuilt the whole top half of my motor and it still idles as high at 1500rpm's at start up. As long as it goes back down to normal, it's nothing to worry about.
Old May 25, 2008 | 02:49 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My '97 LT1 does that too... jumps to about 1500, then slowly drops back down to about 1000 over about 5 seconds or so. I'd say its normal. Fuel injected cars pump in quite a bit of fuel on a cold startup, so they usually also have the IAC pretty far open too so its got lots of air and fuel for an easy startup, similar to what a choke does on a carbureted engine. Once the engine is started, the higher-than-normal rpms burn off the excess fuel faster and build up oil pressure quickly. Then it will drop it down to its normal cold idle presets.
Old May 25, 2008 | 03:22 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Its normal on 3rd gens. It helps with warm the engine up quicker during a cold start and build oil pressure.
Old May 25, 2008 | 05:52 PM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
yea i would agree that this is normal. both third gens i have owned have done the same thing even when they were bone stock.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
