Help looking up an engine code.
Old May 25, 2008 | 09:50 PM
TexasRebel's Avatar
Car: 1982 Camaro Berlinetta
Engine: LG4-V8
Transmission: A3
Does any one know what I need to find out what kind of car this engine came out of?
Old May 25, 2008 | 11:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help looking up an engine code.
Stamped numbers on a pad in the block in front of the passenger side head.
Casting numbers just give you a rough idea about the casting. Casting numbers can at least let you know if it's a 305 or 350 block but won't tell you what the engine was out of..
Old May 26, 2008 | 08:54 PM
TexasRebel's Avatar
Engine: LG4-V8
Transmission: A3
Here is the casting number V1205UZH. Thanks
Old May 26, 2008 | 11:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's not a casting number but it's what I wanted.
V = Flint Michigan engine plant
1205 = December 5
UZH = 1991 350 from a truck. Rated at 210 HP with a TBI. RPO code L05
Old May 27, 2008 | 01:37 AM
TexasRebel's Avatar
Engine: LG4-V8
Transmission: A3
Thanks. Didnt really give me the info i wanted but maybe you can still help. Here is my problem, my buddy bought a 91 blazer from his uncle. His uncle said the engine was a 350 4 bolt main. My buddy blew up his engine, so last weekend we tore it apart to find out it was a 2 bolt main. We want to know if this is the stock engine or if somebody switched it out. Thank you for all your help.
Old May 27, 2008 | 08:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
There should be another set of numbers stamped into the block in the same location. Those numbers will match the last numbers in the VIN number of the vehicle.
Old May 27, 2008 | 03:24 PM
TexasRebel's Avatar
Engine: LG4-V8
Transmission: A3
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
