Burned Sensor ??
Old May 26, 2008 | 08:43 AM
J.Cutta's Avatar
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
Burned Sensor ??
I was doing a tune up and there is a blue connector just above the starter on the right side of the engine that goes into the engine block. Its on a 92 camaro RS 305..I put it back but it is cooked to hell
Old May 26, 2008 | 08:47 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Transmission: 700R/700R
Axle/Gears: 3.42 Posi/3.27 Posi
Re: Burned Sensor ??
That is either the knock sensor wire or the primary fan wire.
Old May 26, 2008 | 08:55 AM
J.Cutta's Avatar
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
The car has been running a bit hot...But the fan is coming on though...Where can I find a replacement?
Old May 26, 2008 | 08:59 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
I am not sure if you can get one at the parts store but my best guess is the salvage yard.
Old May 26, 2008 | 09:19 AM
J.Cutta's Avatar
Car: Camaro RS
Engine: 305 TBI
Axle/Gears: 3.45
Thanks for the help..I did some broswing and it turns out it is the knock sensor just below spark plugs 4/6. I'll have to call around to try to find it. But in the mean time it didnt throw a check engine light. does that mean it is fine for now?
Old May 26, 2008 | 09:25 AM
hoseman007's Avatar
Car: 92 RS/ 87 T/A
Engine: 305/L98
Should be fine.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
