so many to choose from..
Old May 26, 2008 | 02:18 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
xe-294 xfi-292 xe-300 just cant make up my mind really....
basicially its an all forged 355, rods are h beams 4340 eagle crank speedpro flattops or equivalant..... afr 195 eliminators a gasket matched stealthram with 30lb svo injectors and bbk 58mm throttlebody, and it will be backed with a t56.. compression will be in the 9.2:1 range for either boost or a 200 shot.....
chevy high performance recently done a 357 with the eliminators and the 294, made like 530 at 6400.... i'm guessing the 300 will shoot it to near 7000 rpm for max power........
i'd like to shift before that, plus make 530+hp..... just can't figure out which one will do the best job out of the three.....
suggestions? i need someone with good airflow math and sound mechaincs points here, cause fellas i am really stuck on this decision.....
thanks
adam
Old May 27, 2008 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would say none of them, and get a cam designed for the shot instead.
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Victor6
Aug 30, 2015 02:09 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
SLAYER6669
Apr 6, 2001 10:08 PM
