AC out of Windshield Vents
Old May 26, 2008 | 02:18 PM
72SSboy's Avatar
Car: 1988 IROC-Z
okay -- I thought I was mechanically inclined.. but, the ac in my 88 IROC is totally kicking my ***.
I've got a new compressor on.. new dryer.. new switch in the back of the dryer.. converted to 134a.. and YES!! It's cold as can be.. and only blowing out of the vents by the windshield.. you know where the defroster blows.
I looked underneath.. I see one vacuum connection on the passenger side kick panel.. another just to the drivers side of the radio/ac pod. Pulled em off.. no vacuum.
Looked under the hood.. and there's a vacuum line coming off of the passenger's side of the intake.. that appears to be headed toward the passenger compartment. It's just broken in two.. I don't see where it goes.. Once the car cools.. I'll see if I can see the other end of it.
Is this the line to control the vents? Also, isn't it just mechanical.. I live in Texas and won't need the defroster too much.. I'd like to have it correct.. but, if it's a major deal.. can't I just set it up to ALWAYS blow out of the vents?
Thanks a million for the great help as usual..
j
Old May 26, 2008 | 03:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: AC out of Windshield Vents
Sounds like that's your problem. The AC/Heat switch is vacuum controlled.
Old May 26, 2008 | 04:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And when there's a vac problem, the default is defrost. Fix the line and my guess is you'll be good to go.
JamesC
Pac J
May 17, 2020 10:44 AM
Bohemian
Aug 15, 2017 05:11 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
