What to do with Vortecs?
Old May 27, 2008 | 11:24 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I picked up a set of 906 Vortec heads with about 75k miles on them and I was wondering what machine work I should done to them. I was planning on having screw in rocker arm studs, and I want to use the beehive springs for lift. I know I need to have them checked for cracks but what else should I have done? Do I need to do anything with the valve guides? 3 angle valve job? I would like to keep my cost down as much as possible. Thanks!
Old May 27, 2008 | 07:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: What to do with Vortecs?
First, check em for cracks - especially between the intake/exhaust valves. They have a bad habit of cracking there. If they check out, then have the necessary machining done (planed if needed, valve job, new valves 1.94/1.60 sizes (thats a bigger exhaust valve, the intake is ok though as-is), maybe have the spring boss cut for larger diameter springs if you want, etc)
After thats done, then you can have them cut down the valve guides to accomodate a higher lift cam, and have the pressed in studs pulled out and the bosses machined down and tapped for screw-in studs, and guideplates if you want to but that requires opening up the pushrod alignment hole as well (no big deal).
Old May 28, 2008 | 07:17 AM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I was thinking of using the beehive springs because I heard a lot of good about them in regards to valve float as I am running a roller cam, and I saw a dyno test and they actually made 7hp more. I know the springs are expensive but I think it would be the same price as the machining. Should I have anything done with the valve guides? Should I have new ones pressed in?
Old May 28, 2008 | 06:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, new bronze thick walled guides are probably needed. They can check if you need it with a valve though.
Yes, you really need to have the valve guides cut for more lift. Get the shop to cut them down like .100" and make them ~.500". That way you can use off the shelf positive seals.
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
