cars on the side of the road, loud ticking...
Old May 23, 2008 | 07:02 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
I noticed earlier in the day that if i got on the gas pretty hard it made a loud ticking or knocking, i drove it to work and when i got out of work and was driving it home it got consistantly worse, i was barely giving it any gas and it was doing it so when i was going up a hill it made a pretty loud one and i felt it in the gas peddle and heard the rpms lk jump down and u put in the clutch, it stalled. It seemed to be coming from the #7 cylinder.
I adjusted all the rockers, tightened the header, tightened the intake manifold, adjusted the timing, nothing helped.
Anybody know anything? this is the second week i have had my car out.... really sucks.
Old May 23, 2008 | 08:23 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: cars on the side of the road, loud ticking...
Can you get a video of it or discribe it in a little more detail? How is your oil pressure?
Old May 24, 2008 | 09:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
A compression test may be in order.
How did you determine that it was coming from cylinder 7?
Old May 24, 2008 | 10:04 AM
brodysZ28's Avatar
Engine: 383
the oil pressure was fine the whole time, trust me i made sure i was checking it every 5 seconds... at first i thought it was something smacking against the firewall because it really sounded like somebody was smacking a wrench against the firewall. it really sounds like #7, its on the right side of the motor if you are standing up front, and its all the way back... im going to pull that spark plug in a little bit and see if i can see anything...
Old May 24, 2008 | 05:11 PM
brodysZ28's Avatar
Engine: 383
so i couldnt pull the spark plug with the headers on, i got it towed to the place where i get it worked on, i will have them do a compression test. do you guys think the motor is on its way out? i just put the motor together, only things i didnt replace was pistons/rods/crank...
Old May 24, 2008 | 07:05 PM
mylittlehoney's Avatar
sounds like a rod,
when I saw ticking I though it was just a header gasket :0
Old May 24, 2008 | 07:41 PM
brodysZ28's Avatar
Engine: 383
yea, def not header gasket, i got one of those leaking already and this is about 5 times louder. what could be contacting what to do this?
Old May 28, 2008 | 06:43 PM
brodysZ28's Avatar
Engine: 383
I just picked up my car... first off, my friend that waqs helping me out adjusted the valves wayyyyy to tight. The guy who was working on it pulled a bent pushrod out that he thinks was from being overtightened, but the same valve that that pushrod came out of leaked when he did a leakdown test but it seems to be running fine... so he said there could have been a carbon deposit stuck in there causing it to leak.
as a result of the overtightening, some of the lifters may have collapsed (there is a new ticking) so i am gonna get some more, but should i replace ALL of them or just the bank that was overtightened? Also will anything be damaged by running it with collapsed lifters?
As of the knocking I was hearing... it didn't do it after he replaced the rod and reajusted the valves. wierd huh?
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Exxon Limited
Aug 9, 2015 08:13 PM
