Help,. car wont start, no fuel getting in
Old Jun 1, 2008 | 10:18 AM
Squiernmr's Avatar
i was driving in the city and my 92 camaro just died on me. i popped the hood to check the injectors and i saw that no fuel was squirting into the manifold. I think it may be the in-tank fuel pump because i knocked on the tank and fuel started flowing. Now, the car just wont start at all. Is that pump the problem? If not, then what is it?
Old Jun 1, 2008 | 01:09 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Help,. car wont start, no fuel getting in
Sounds like the pump to me, try disconnecting the fuel line from the tbi or tpi whichever you have and aim the line to a gas can, turn the ignition on without starting and see if fuel flows thru the line. Could be low pressure from the fuel pump also especially if you have TPI.
Old Jun 1, 2008 | 11:06 PM
Squiernmr's Avatar
ok i will try that. if the pump is the problem, what is the best way of replacing it . i already have a high performance high flow pump, now how do i get the tank out?
Old Jun 2, 2008 | 07:32 AM
jreze8's Avatar
Car: 1991 Iroc Z28 Camaro
Engine: 5.7L V8 350CI
Transmission: Stock
Axle/Gears: Stock
I have a 1991 Z28 and it just died one day in a parking lot. It acted like it wasn't getting gas to the engine. I found out that one of my injectors was bad and according to some stuff floating around, this car will shut the fuel system down when one injector dies. I have had two go out within a day, I finally just put 8 new ones in. It also made it run cleaner, passes emissions!
Hope I could help... Let me know if you have any questions...
Old Jun 2, 2008 | 07:49 PM
Squiernmr's Avatar
ok guys thansk for the help and i ended up installing a high performance fuel pump. Now my guage is way passed full and i think its the little measuring thingin the tank. you think it may have gotten stuck on something??
Old Jun 4, 2008 | 10:58 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
so it fixed your problem then?
Old Jun 4, 2008 | 02:17 PM
Squiernmr's Avatar
ye the motor runs strong and that fuel pump is great. Now i just got to figure out my fuel reading problem. I will take out the tank again and re-install the pump with the measuring device so that should fix this situatuion
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
