What size bit for the smog pump bolts?
I have a 92 305(edit: TBI), I'm trying to take out the AIR pump(seized), but the two bolts that hold it on are like Torx or something.. I don't have anything big enough to fit, and I don't want to buy a bunch and then return the ones that aren't the correct size.. Help?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: What size bit for the smog pump bolts?
knight72
Aug 10, 2015 09:32 PM
