computer controlled distributor swop to a mechanical, vacuum advance HEI
Old Jun 5, 2008 | 02:27 PM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
how do you do this ?
can you still use your computer and make it smog legal
Old Jun 5, 2008 | 04:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: computer controlled distributor swop to a mechanical, vacuum advance HEI
Maybe.
Depends on the laws of your state.
You can make it pass a sniffer, but not a visual inspection.
Why don't you cough up some specific info so we can give you some specific answers eh?
What state?
What year car?
what engine?
What transmission?
Why do you want to do this mod anyway?
Old Jun 5, 2008 | 05:31 PM
Car: 83 Camaro
Engine: 5.0
CA
83 camaro 305 Computer-Controlled Quadrajet 2pc Rms 5spd mech.clutch stock
puttin a used 350 1976 with all stock oe intake carb smog vac ect from 83 for now need smog
if my computer controlled timing is f**ked mechanical will ajust right
Old Jun 5, 2008 | 05:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
Is your computer screwed? Will it not adjust timing for you right now? If it works now, stick with it. It's better than a mech setup, and WILL pass you smog.
CA is pretty strict. I'm the last person you'd want to ask, but I think Five7kid is pretty knowledgeable about that type of thing, he might post in here.
If you need to go to mechanical dist, you'll need to go to mechanical q-jet carb, and then you're done, since you have the 5 speed. But will it pass smog without the factory parts in there? (ie CC carb and dist?) I don't know.
Old Jun 5, 2008 | 05:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can't put a vacuum/mechanical distributor with a computer controlled carb. Period, end of discussion.
You can't pass CA emissions test/inspection with a vacuum/mechanical distributor and non-CC carb. Ditto on the status of the discussion.
Technically, you can't put that engine in your car. You can put an '83-up carb 350 in if you call it an engine from a Caprice/Parisenne (sp? Pontiac version of Caprice)/Roadmaster and have all of the emission equipment on it that came in those cars, and go through the "motor change" process.
You may be able to install the engine, with all of your 305 equipment operating properly, and get it through the standard inspection/testing process if you keep your mouth shut.
Is something wrong with your 305 stuff? If so, we can probably talk you through it. But, give up on trying to do what your topic line says.
Old Jun 5, 2008 | 06:28 PM
Car: 83 Camaro
Engine: 5.0
yea will stay with stock305 equipment and make it work
Thanx for the info
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Jan 29, 2017 07:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
