Does my 5.0L have a fuel pump lobe to drive a mechanical fuel pump
Old Jun 5, 2008 | 04:16 PM
rc59's Avatar
I'm doing an engine swap between a 85 El Camino and a 1990 camaro. The El camino has a GM 350 crate motor, the camaro has the stock 305 with TBI code E. The TBI is going on the 350 and staying in the camaro, the 305 is going in the el camino with a carb. My question is, does the 305 stock cam have a fuel pump lobe to drive a mechanical fuel pump rod or do I need to use an electric in-line pump.
Another question I have is about switching the distribtors. The 305 is a roller cam the 350 is not. Do I have to swap the distributor drive gears. Which cam uses bronze and which uses iron.
Thanks for your help.
Old Jun 5, 2008 | 04:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Does my 5.0L have a fuel pump lobe to drive a mechanical fuel pump
edit
Your cam should have a fuel lobe. My L98 roller cam has one
Old Jun 5, 2008 | 04:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I didn't get the impression a cam swap between the engines was being planned.
You don't need to worry about the cam gears. They are both steel, neither bronze, and both fine with the cam they will be running on.
Old Jun 5, 2008 | 04:41 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
OH i see! haha i read it wrong. i get it now, el camino doesnt have an electric in tank pump
Old Jun 5, 2008 | 05:04 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
the El camino, man i miss mine so much. 84 red and black. Hold on to her!
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
R3500
Aug 17, 2015 12:16 PM
