Engine "misses" at constant RPM.
Old Jun 6, 2008 | 09:30 AM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
RE: 1988 IROC-Z vert, 5.0 TPI, 5 speed
My ride sat up for 3.5 years after Hurricane Ivan with no starts at all. In March I had her flat bed towed to my mechanic. He drained & wiped the fuel tank, replaced the fuel pump, changed plugs (plug wires are +/- 10 years), ran ejector cleaner, cleaned air intake, new air filter. She has good acceleration and drives smooth while accelerating and at relatively high RPMs; however, at steady low RPMs she "bumps". It's like she is not firing all cylinders. Sorry if I am not being descriptive. Any sugestions you may have on what I need to have done would be much appreciated.
Old Jun 6, 2008 | 09:53 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Engine "misses" at constant RPM.
things I would check would be the spark on all plugs and gaps, then the fuel filter, fuel pressure and check for any vacuum leaks.
theshackle
Sep 17, 2020 08:26 AM
lakeffect2
Aug 23, 2015 08:44 AM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
