Which of the following could cause...
Old Jun 6, 2008 | 03:50 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
So I have three problems/ideas going on with my '86 305 TPI and I want some advice as to which may be causing my starting problem. The motor starts just fine when warm, even less than 100 degrees but when I first start it for the day or after about 8 hours of not running, it takes a while to turn over and when it does, I have to give it gas for a good 20-30 seconds before it holds it's own idle. Then when I drive it after a cold start, it feels like it lacking power. After about a minute of driving it and it warms up, everything is perfectly normal. Here are my ideas, tell me if you think any of them is my problem:
- TPS, it's brand new but I can't get it adjusted correctly and it is still throwing a code 22. The light goes away when I accelerate usually and comes on when braking (throttle closes).
- 02 Sensor, it's welded on to only one of the cylinders of my headers and very close to the block... I need to move it, I know.
- Engine Temp Sensor, it's never been replaced and I've heard it could be the problem???
I have brand new fuel injectors, new fuel filter, new disty cap, get tune-ups done regularly, the pump buzzes as soon as I turn the key to on. I also have a brand new IAC and cleaned the throttle body out... Help please.
Old Jun 6, 2008 | 03:53 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
Re: Which of the following could cause...
i had those symptoms on my taurus...cured it with a new IAC.
Old Jun 6, 2008 | 05:55 PM
Car: '86 Iroc Z
Anyone else?
Old Jun 7, 2008 | 11:50 AM
Car: '86 Iroc Z
bump
brian163
Sep 2, 2010 06:38 AM
vandal711
Jul 27, 2010 04:32 PM
spudz
Dec 19, 2008 12:57 PM
88tpi350
Sep 10, 2008 01:59 PM
