leaking thermostat housing, 305 TPI
Old Jun 9, 2008 | 08:25 PM
bbullsj's Avatar
i have an 85 trans am with a 305 TPI engine. i have done everything i know how to do but i can't get the thermostat housing to seal to the intake. i've tried 3 times now and still nothing. i've cleaned both surfaces the best they can be. i've torqued them to the proper specs. i've tried several gasket makers after just the regular gasket didn't work. any help would be very helpful, thanks.
Old Jun 9, 2008 | 10:45 PM
vette gator's Avatar
Car: 85 Z28
Re: leaking thermostat housing, 305 TPI
I put a thin coating of RTV on both sides of my T-stat gasket, then rubbed between my finger and thumb to work the sealant all around it before installing and torquing down. Even after doing this, I still saw some coolant pooled on the intake manifold next to the T-stat housing. A pressure tester showed that it was actually leaking from the upper radiator hose / housing seal. Double clamping the upper radiator hose to the housing solved that problem.
1992 Trans Am
May 10, 2023 07:19 PM
perZ
Aug 15, 2015 01:17 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
