Swapping to Serpentine -- Need help with Smog Stuff
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I'm going to be installing a serpentine belt set up into my 84 T/A. I want to keep the smog equipment. I would like to reuse my original diverter valve and other smog equipment that the A.I.R. tubes run to and was wondering if anyone who has done this swap knows if my original brackets (From the V-Belt) will work or will I have to get a setup from a serpentine car? Thanks!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Swapping to Serpentine -- Need help with Smog Stuff
http://paceperformance.com/index.asp...D&ProdID=36720
Maybe something in the following link will prove useful:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Car: 1984 Trans Am
I have no real experience, but it would appear that the air pump may bolt-up to the serpentine bracket.
JamesC
JamesC
Transmission: 4L80E/4L80E
Can't say without seeing your eBay set-up, but most serpentine set-ups run the water pump from the back side of the belt, meaning it's turning in the opposite direction from stock. If that is the case with yours, you can't use your stock pump because it won't turn in the proper direction.
Beat me to it, Kid. You'll also need a few misc pieces, but I think the link second link will provide what you need.
JamesC
JamesC
Car: 1984 Trans Am
I didn't understand that you were buying a factory system - there are a lot of businesses selling stuff on eBay.
You will certainly need a serpentine water pump. It would probably be easiest if you picked up the A.I.R. stuff off of a TBI car, but I'm not sure what all connectors changed.
I do know that air conditioner and alternator electrical connectors changed between '84 and the serpentine years. You're biting off more than just the nuts & bolts.
Car: 1984 Trans Am
Car: 1984 Trans Am
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have done this conversion to my 82. You will need a 88-92 ac hose off the AC compressor to make the change over. I can't say anything about the smog pump because my car does not require a smog pump due to a CARB BAR sticker exemption.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
